Our ACS (5.3) has self signed certificate, we have exported it and declared it in Certificate Authorities.
We have exported it to have a Trusted Certificate for client machine.
This certificat has been installed on a laptop.
The wlc is successfully setup for eap (peap & eap-fast has been tested > ok)
I have this error in the log:
12514 EAP-TLS failed SSL/TLS handshake because of an unknown CA in the client certificates chain
I think the Access Policies (identity & authorization) are misconfigured:
> I allowed Host Lookup, PAP/ASCII, MSCHAPV2, EAP-MD5, EAP-TLS, PEAP, EAP-FAST
> Identity: System:EAPauthentication match EAP-TLS
id Source: AD in which AD, Internal Users, Password based, certificate based CN Username are enabled
> authorization: System:WasMachineAuthenticated=True
Thanks for your help,
regards,
