01-22-2013 08:45 PM - edited 07-03-2021 11:23 PM
Hi all ,
is it possible to install cisco acs 5.4 on vmware 8 workstation ??
thanks in advance,
pandian G K
Solved! Go to Solution.
01-22-2013 10:41 PM
Yes it is.
But note when creating the VM do not specify the ISO image of the OS and choose that you will choose it later.
Here is a useful link:
https://supportforums.cisco.com/message/3714114
Amjad
Rating useful replies is more useful than saying "Thank you"
01-22-2013 10:41 PM
Yes it is.
Amjad
