ACS 5 Custom RADIUS attribute?
We are testing ACS 5 with Cisco and Juniper switches. Everything is working well, except we need to use a certain Juniper RADIUS attribute for downloadable filters (think downloadable ACL). The attribute is not listed in the ACS -> Config -> Dictionaries -> Protocols -> RADIUS -> Juniper section, and I cannot see a way of adding/editing the dictionary.
Any ideas?
Gustavo Novais
Level 5
Level 5
I've also tested ACS5 a while ago with Cisco, HP, and other manufacturers...
Unfortuinaltely that's one of the points where ACS 5 is not yet mature...
Attribute addition is not yet supported, but will definitely be in roadmap.
There was an ask the expert event a few months ago about ACS5. You might want to take a look at that.
Best of luck
Gustavo Novais
I believe ACS 5.1 will have this feature, ACS 5.0 is limited in this regards. If this can not wait, you may use ACS 4.2
Thank you both for the replies. I'll check out the Ask the Expert, and I am now loading up ACS 4.2 eval to check it out. Looks like CSUtil.exe and I are going to get very chummy.
