Actual number of APs supported with WCS base license
jkaras
The licensing guide indicates the WCS base license is appropriate for an environment with 500 lightweight access points.  However, later in the same document, it provides an example to upgrade the base license to support 800 APs.  Is there a limit to the number of APs supported with the base license (other than server capacity)?
I am not performing a WLSE-WLC conversion.
We are running version 7.0.172.0.
I am using the licensing guide at http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/product_data_sheet0900aecd804b4646.html
Stephen Rodriguez
The differnece between the licenses is all about features.  IF you aren't needing anything advanced you can have a base license up to the max your server can handle.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
