Add a simple wireless config to a Cisco 877 wireless?
whiteford
Hi, I have a working Cisco 877w on an ADSL line. I'm trying to find out how I can add a simple wireless network to it? I can't find any instructions or examples on how to do this either in CLI mode or SDM.
Hope you can help
drolemc
Level 6
Level 6
Here is a useful document which explains in detail how to setup a wireless connection using the 870 series wireless router.
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html
drolemc
Level 6
Level 6
Thanks that's great.
Just one question, I currently have VLAN 1 configured as my routers IP for my LAN wired users and DHCP aswell. How would I still make sure the wired users get an IP address and my router has an IP as I see VLAN1 is set to "no IP address"?
