Add device using REST API in Cisco Prime
franktonjes
Hi All,
I need to add controllers into Cisco Prime using the REST API. I am able to get information out of the REST API, but it seems the documentation on the POST and PUT calls are only shown for config templates.
Can someone please shed some light on how to add controllers into Cisco Prime using the API please?
We have Cisco Prime Infrastructure 2.1.
Many Thanks,
Frank
gohussai
Level 4
Level 4
Check the following official document on REST API for PI.
http://249459ec2cf8839ca4b8-2690f879103214107f979ba5105d745b.r47.cf2.rackcdn.com/Prime%20Infrastructure%202.x.pdf
https://developer.cisco.com/media/prime-infrastructure/api-reference/szier-m8-106.cisco.com/webacs/api/v1/indexcc3b.html?_docs
Hope this is helpful
PETER MOOREY
This might help...
https://www.linkedin.com/pulse/get-automating-cisco-prime-infrastructure-api-peter-moorey
Pete.
smp
Level 4
Level 4
I recently brute-forced my way through this successfully. See my braindump post here:
https://communities.cisco.com/thread/55694
Briefly, you need to build the right data structure, then use the bulkImport method with the PUT verb.
