Add vlans to Wifi controller
lconcepcion
We have an Air-CT5508-k9 controller and I need to add another dhcp range to the controller from our external dhcp server. first time working on this controller and cant find were I would specify the new range to use. I would think you should just have to assign the vlan for the dhcp range to the wifi ssid but I cant find the setting. could some help guide me to set this up. Thanks.
Rasika Nayanajith
In WLC, you simply define a dynamic interface with allocated vlan tag. Refer this link & it explain this scenario at the end
https://rscciew.wordpress.com/2014/07/16/dhcp-with-the-wlc/
Rasika
*** Pls rate all useful responses ***
Thanks for pointing me in the right direction.That was the information I needed to know.
