Adding 9120AX-E to Mobility Express network with a 1526I acting as WLC
key_tone_9926
We have a network of Cisco AP1562I running mobility express. I wanted to see if we can add a Cisco 9120ax to the network and run in Mobility Express as a subordinate AP.  Plus keep the AP1562I as the the WLC. As the 1562I are end of sale.
2 Accepted Solutions
marce1000
 - Checkout : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#mobility_express_solution
               Looks you need 8.9.111.0 or above
 M.
Scott Fella
Just to add, you always should keep the matrix @marce1000 posted handy.  Before you buy anything new or old, you need to make sure what that device supports and what your existing infrastructure can support.  The matrix will also help you with planning your next steps, like if you have to upgrade and if that new code supports other ap's you have existing.
Also knowing that Mobility Express has gone away, maybe it's time to look at a controller, which is so much easier to manage.
-Scott
marce1000
 M.
Scott Fella
-Scott
Thank you all for your help.
