adding additional dhcp scopes to a 5508 controller
Shawn Purdy
Level 2
Level 2
Ok guys and gals. Here is my situation
I have two 5508 controllers configured with an internal dhcp scope. The scopes on each controller are a /22. I need to expand the scope to provide more addresses. Is there an easy way to add a second dhcp scope without making changes to the existing scope? If so how will the clients devices be able to access that ip address range?
Stephen Rodriguez
there is not. You will need to change the mask on the gateway and the scope. The WLC does not support secondary addresses.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
