Adding_APs_To_Floor_MAP
Hello community,
I have an issue with adding APs to Cisco DNAC floor map, When I click edit>>add APs I can't find the list of APs associated with this floor, I want to know if the APs should be provisionned or just discovered by the DNAC.
Thank you for your support
Best regards
The problem is resolved, I think it was a problem with services
