Additional info at Site view in Location Manager
balsutiev.s
Do anybody know if it possible to put/attach additional information file(s) to every site in Location Manager?
At the moment I just found out the only string in "Floor" properities for any coments. But I can't put there enough information in readable format.
Also, may be it's possible to put that info in Reports of every particular site?
Thank you in advance!
thomas.chen
Level 6
Level 6
I dont think you can add any more information other than the what it allows under the "Floor" properties. You have to organize your data within that space and manage your devices.
Thank you very much for answer!
WLSE isn't able to perform that simple task.
