Administrative services - Wireless LAN Controller
lAhmed Saadl
Level 3
Level 3
Dears,
 I've WLC 5500 series, and I need the administrative services to be restricted to only network hosts that require access. Could you please support with the steps that should be followed?
Mark Elsen
  - You need to look into using CPU ACL's : https://community.cisco.com/t5/wireless/two-questions-about-cpu-acls/m-p/2845703
        https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/71978-acl-wlc.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 M.
Thanks Marce, you just get the point. I just applied it to WLC, and I hope I get nothing related to administrative services after the security vulnerability test takes place.
Thank you very much for that answer.
