Showing results forĀ
Search instead forĀ
Did you mean:Ā
Aeronet AIR 1832I-E-K9 Wireless AP
osman869
I have three AERONET Aeronet AIR 1832I-E-K9 Wireless AP  connected to Catalyst 9200 Switch I dont have any wieless controller. I need to configure them I have assigned them IP using "Capwap ap ip netmask"
How can I make them work as an AP and I want to access the GUI How can I ?
Thank you.
You have to download the "Mobility Express" image from Cisco and convert the AP from CAPWAP to Mobility Express. There are tons of guides for this on the internet. Most are outdated but you should get the idea.
Thank you Karsten for reply.
Is there any option that I deploy without mobility express. I want to configure an autonomous access point with catalyst switch.
Is there any possibility as C9200 SW shows enable wireless controller option in GUI what does that means ?
Thanks.
On the Catalyst 9k ist is the Embedded Wireless Controller. But I think that is only available on the 9300 and better:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-744299.html
Activating Mobility Express on the x800 AP is the way to go if you don't have any other controller.
