After deep sleep does not connect to wifi
OSCAR RODRIGUEZ
My customer has WiSM2 7.6 and cannot connect to SSID if your MACBook Air  into deep sleep. If the wifi is turned off I reconnected everything works ok.
What settings can tune?
Thanks!
OSCAR RODRIGUEZ
I forgot MACBook Airwith the latest OS X Maverick
Thank!
I have seen this problem too.
Im a Mac user. I can tell you Ive seen this problem as well. I did a capture a few months ago and confirmed my issue was my Mac. There wasn't any settings I could do on the controller that would fix the client not wanting to connect.
