AIR-ANT2513P4M-N Material
hueyfiasco
Hi all,
I'm looking into this antenna and was able to find a drawing with some dimensions with parts called out. However, it didn't specify the material of the parts like the bolts and mounting arm. Is it possible to obtain this information? Also would 3-D models of this be available as well?
Thank you,
Huey Fiasco
0 Replies 0
