Air AP 1242AG-E-K9 How to upgrade firmware lightweight
tanner.zaitt
Level 3
Level 3
Hi, my question is how we can upgrade firmware of Air AP 1242AG-E-K9 ?
I am with these things:
-Cisco console cable
-Cisco Air AP 1242AG-E-K9
-Cisco Poe adapter
-Cisco AP antennas
- And I am with access to Cisco resources to download firmwares.
But how I can install new firmware?
Am I on the right way?
First I find that link:
https://www.cisco.com/c/en/us/support/wireless/aironet-1240-ag-access-point/model.html#~tab-downloads
I want Lightweight AP IOS Software.
And I should download it:
Aironet 1240 AG Access Point?
What is next step?
24 Replies 24
CSCO11304974
1. Aironet 1240 AG Series Access Points allow for operation at temperatures as low as
-20°C (-4°F) while the connectorized version of the Cisco Aironet 1000 Series Access Point (AP1020) provides a 0°C (32°F) minimum operating temperature. This difference can be critical in certain operating environments.
Software Download
Select a Software Type
Please go through this for upgrading Air AP 1242AG-E-K9 How to upgrade firmware lightweight.
What is EXACTLY your intention of doing this? First, the AP is loaded with CAPWAP image and converted it to autonomous IOS. Next, you want to convert it back to CAPWAP?
What exactly are you trying to accomplish?
I successfully changed IOS of AP 1242, from Autonomous To Lightweight, with TFTP server where I put Lightweight IOS firmware, and from 1242 with Autonomous IOS I run tftp command to load Lightweight IOS and overwrite Autonomous with this Lightweight IOS.
Now the AP 1242 is with Lightweight IOS and now search and see WLC but can't connect .
I try to say to 1242 ip of WLC and nothing is happened, now I run command debug lwap client event and I see certificate unknown alert from ip of WLC IP and
bad certificate alert received from peer.
Console into the AP and reboot.  Post the entire boot-up process.
We want to see what the AP is doing.
Now I don't have access to AP  but these photos are from 27.0.4.2018.
Received FATAL : Certificate unknown alert
Bad certificate alert received from peer
You really, really need to read this:  FN - 63942 - Wireless Lightweight Access Points and WLAN Controllers Fail to Create CAPWAP/LWAPP Connections Due to Certificate Expiration - Software Upgrade Recommended
The AP is probably >10 years old and the MIC has expired.  This is why the AP won't join the controller.
Thank you so much !
You are right.
My AP is too old:
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7900-series/end_of_life_notice_c51-726425.html
I read what you posted me.
I will try this:
"This workaround should only be used in order to allow the APs with expired certificates to join the WLCs just long enough to upgrade the software.
If the certificates have expired, disable Network Time Protocol (NTP), and then change the WLC clock time to a recent earlier time when the certificates were still valid. If you set the clock back too far, the newer APs might not be able to join. Once the software has been upgraded, and the affected APs have joined, the WLC clock should be reset to the valid time."
But before try it I will try this:
(WLC)>config ap cert-expiry-ignore {mic|ssc} enable
With few words this is the way to connect AP with expired certificate?
Hi I need your help because I am not sure in myself.
I didn't do anything with WLC, because it is in production environment.
Can you tell me someone what will happen if I change date of WLC to past date where AP with expired certificate will valid and they will talk each other and AP will join to WLC?
What will happen to other APs that already joined to WLC while I do this change with date?
And If AP is joined with expired certs and another AP's not affected of these changes, what will happen when I set the actually date and time?
And the same question what will happen if I use this command in WLC :
And  join AP and after that  if I use this command:
(WLC)>config ap cert-expiry-ignore {mic|ssc} disable
I only think what will happen but I am not sure :
If I set WLC to ignore expired certs, then the AP will join to WLC and WLC will load in to AP new IOS with valid certs I am right?
And now I can disable ignoring expired certs?
The WLC is 5500 series.
I tried to install the newest and the oldest IOS for this AP, but it didn't help, only I receive IP address from dhcp of vlan network of WLC and I receive errors with certificates.
Is it possible to write new valid certificates in AP?
Or delete expired certificates and export from another AP valid certificates and import them in this AP ?
My question with one sentence  is how can I join this AP with expired certs to WLC elegantly  without break production environment ?
Notes about troubleshooting and gathering information:
Ignoring expired certs:
For Version 7.0.252.0, use this command:
(WLC)>config ap lifetime-check {mic|ssc} enable
For Versions 7.4.140.0 and later, use this command:
 Finding SN to identify from Cisco web site information of certificates status
(Cisco Controller) >show ap inventory all
Inventory for lap1130-sw3-9
NAME: "Cisco AP" , DESCR: "Cisco Wireless Access Point"
PID: AIR-LAP1131AG-E-K9, VID: V01, SN: FCZ1128Q0PE
NAME: "Dot11Radio0" , DESCR: "802.11G Radio"
PID: UNKNOWN, VID: , SN: GAM112706LC?
NAME: "Dot11Radio1" , DESCR: "802.11A Radio"
PID: UNKNOWN, VID: , SN: ALP112706LC
To find in AP information about MICs (Manufacturer Installed Certificates):
AP_CLI#show crypto pki certificates
CA Certificate
Status: Available...
Certificate
Status: Available
Certificate Serial Number: 728AF4350000001E4C89
Certificate Usage: General Purpose
Issuer:
cn=Cisco Manufacturing CA
o=Cisco Systems
Subject:
ea=support@cisco.com
cn=C1130-001c58b5b3a4
o=Cisco Systems
l=San Jose
st=California
c=US
CRL Distribution Points:
http://www.cisco.com/security/crl/cmca.crl
Validity Date:
start date: 04:22:10 UTC Jul 11 2007
end date: 04:32:10 UTC Jul 11 2017
Associated Trustpoints: Cisco_IOS_MIC_cert
 To find information about  SSCs (Self-Signed Certificates):
AP_CLI >show auth-list
AP with Self-Signed Certificate................ yes
All AP SSCs have an expiration date of January 1, 2020.
Find WLC serial number:
WLC_CLI>show inventory
Burned-in MAC Address............................ 24:E9:B3:43:C4:E0
Maximum number of APs supported.................. 75
NAME: "Chassis" , DESCR: "Cisco 2500 Series Wireless LAN Controller"
PID: AIR-CT2504-K9, VID: V04, SN: PSZ17441ANT
To see all certificates in WLC:
WLC_CLI: show certificate all
Certificate Name: Cisco SHA1 device cert
Subject Name :
C=US, ST=California, L=San Jose, O=Cisco Systems, CN=AIR-CT2504-K9-d0c282d65a20,
 MAILTO=support@cisco.com
Issuer Name :
O=Cisco Systems, CN=Cisco Manufacturing CA
Serial Number :
454384735992863371807890
Validity :
Start : 2011 Jul 26th, 20:17:17 GMT
End : 2021 Jul 26th, 20:27:17 GMT
Signature Algorithm :
rsa-pkcs1-sha1
Hash key :
SHA1 Fingerprint : 98:89:eb:12:2a:98:bc:fe:ad:5b:8f:23:63:0f:47:d1:36:ce:f5:be
MD5 Fingerprint : ba:f3:98:9a:cd:f8:01:08:84:b8:66:3c:6a:6c:d3:05
I solve my problem completely....
Just I removed all content from flash memory of AP1242AG exclude the current IOS Image.
I used to transfer c1240-k9w7-tar.124-25d.JA2.tar with Hyper Terminal xmodem 1k protocol in special mode where the host name of ap is "ap:".
This mode is accessible while turn on AP, holding 20 seconds mode button.
I run command :
set BAUD 115200
Then I run:
copy xmoedm: flash: <name of IOS.tar>
I started Hyper Terminal and send the IOS.tar file.
After ten minutes, my IOS.tar file is there.
I reloaded the the AP with current IOS and run:
debug lwapp client no-reload
debug capwap console cli
archive download-sw /force-reload /overwrite flash:/IOS.tar
Now I am ready with the latest IOS LW for AP!
Now we update WLC with the latest IOS where the command:
Is supported!
And now we can join AP to the WLC successfully.
My mistakes are to much:
I transferred ios to ap with tftp with udp, it's not good practice.
I transferred only one file, only the ios without other files from archive and that is my wrong.
And finally when I do it with right way with Hyper Terminal and with archive of IOS in .tar everything is okay.
emsclinic
Looking for latest lightweight firmware. c1240-k9w8-tar.124-25e.JAP12.tar or newer. Air AP 1242AG-E-K9 is not supported.(
