AIR-AP 2802I-B-K9 wrong country code
ReadersUK
Level 2
Level 2
I just installed 7 x AIR-AP2802I-B-K9 on a 3504 controller. 3 of them have come up ok with country code US (united states) as i would expect, but the other 4 have come up with country code CA (canada) and the radios have shut down.
I have tried setting the correct country code on the controller gui but the command is ignored. The inventory shows i have the correct Hardware with B domain. I have tried various combinations of shuting down the radios, defaulting the config ect but can not set US. Has anyone come across this before?
regards
colin
Sandeep Choudhary
If you have AP with regualtrory doimin -B- (2802I-B-K9) then app AP must come UP if you set the country code US in WLC.
Canada require -A-regulatoiry domain on APs.
Please check if you have right AP for US or not !! If not then ask your supplier to change these.
Dont forget to rate helpful posts
Leo Laohoo
Contact the vendor who sold you the APs and ask them if they can be replaced with correct Regulatory Domain.
Thanks for the reply, we came to the same conclusion and have contacted the vendor.
regards
