AIR-AP1042N-X-K9 to LightWeight conversion
Marcio Ferreira
Hello, My customer have Ap's AIR-AP1042N-T-K9 models, and need to convert LWAP to use them on a controller, but needs an official Cisco documentation to perform.
I found many posts with the statement that this is possible, but no official document from Cisco.
Someone already made this conversion successfully and found that documentation?
Marcio Ferreira
In this datasheet , it says that this AP is available in both mode:
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1140-series/data_sheet_c78-609338.html
How to convert:
First download image from here: http://software.cisco.com/download/release.html?mdfid=283445229&flowid=17961&softwareid=284180979&release=15.2.4-JB5&relind=AVAILABLE&rellifecycle=ED&reltype=latest
and then use these methods to convert -
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
https://www.youtube.com/watch?v=Fiv76UpStKI
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01101110.html#ID1111
Hope it helps.
Dont forget to rate helpful posts
6 Replies 6
Leo Laohoo
Go and download the CAPWAP IOS (called Recovery Image) from the Cisco website.
Unpack the IOS into the AP using the command "archive download-sw tftp://[TFTP IP address]/filename.tar".
Boot the AP.
Make sure you have enabled DHCP Option 43 and/or 60 so it'll be easy to get your AP to find the WLC.
Thank you Leo, but you would have a link or Cisco documentation for this specific model (AIR-AP1042N-X-K9 )?
is a requirement of the customer :/
What documentation are you looking for?  Data Sheet?
A document stating that this model of autonomous AP can be converted to lightweight
How to convert:
Hope it helps.
Is your customer kidding????
We've been converting APs since 2009!  cheeky
