AIR - AP1131AG - E -K9
Ekin Gumus
Hello everyone,
I have AIR - AP1131AG - E -K9 access point and I want to publish second ssid. There is no vlan structures in my local area network. Second ssid will publish same IP address scope as first ssid do. Is it possible to publish second ssid with this settings?
Thanks & Regards
mueddib
Hello Ekin;
Does it ask you? You can set two broadcast ssid and different vlan, correct? please create/config subinterface and BVI config interface.
Please read:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37ssid.html
Exam:
AP(config)# interface Dot11Radio0.1
AP(config-subif)# encapsulation dot1Q 1 native
AP(config-subif)#bridge group 1
AP(config-subif)# interface FastEthernet0.1
AP(config-subif)# end
AP# write memory
AP(config)# interface Dot11Radio0.2
AP(config-subif)# encapsulation dot1Q 2
AP(config-subif)#bridge group 2
AP(config-subif)# interface FastEthernet0.2
AP# write memory
AP(config)# interface Dot11Radio0.3
AP(config-subif)# encapsulation dot1Q 3
AP(config-subif)#bridge group 3
AP(config-subif)# interface FastEthernet0.3
AP# write memory
Please read: https://supportforums.cisco.com/docs/DOC-14496
Thank you for sharing your ideas but I want to establish this wifi without any vlan.
Hi , you can configure 2 different ssids on the same radio with no vlans but the secuirty method should be none.
You will not be able to broadcast more than 1 SSID at a time.
Also at the end having 2 ssids on the same subnet and with the  no secuirty would not make sense because at the end it is the same as having just one SSID
