Air-AP1200
rehan_uet
I am going to order "AIR-AP1231G-E-K9", and it requires external antennas. I need antennas directlty connected with this AP without any cable. Is "AIR-ANT4941" correct antinna for this requirement. If it is correct selection, do i need to order two "AIR-ANT4941" or a single order can fulfil the requirement of two diversity antinaas.
dhusand
AIR-ANT4941 is the correct antenna, and yes you need to order 2 of them.
dhusand
