AIR-AP1242AG-a-K9
Jnhockema
The company I work for just purchased one of these APs and I am having a hard time configuring it. I hae done several searches and I can't find what i'm looking for. It seems that after a factory reset by holding down mode during power on, that I can't get into global config mode. The command config t is not a known command. I am able to get into priv exc mode. Does anyone have any ideas on this?
Yes, the IOS version being loaded and the CAPWAP messages confirm that this AP is in lightweight mode.
You need the Autonomous IOS firmware such as c1240-k9w7-tar.124-21a.JY.tar.
Here is link to a document that explains the IOS images.
https://supportforums.cisco.com/docs/DOC-19607
8 Replies 8
Scott Fella
Post the output from the console when you are powering up the AP.
-Scott
*Mar  1 00:04:17.700: %SYS-5-RELOAD: Reload requested by Cisco on console. Reloa
d Reason: Reload Command.
*Mar  1 00:04:17.701: %LWAPP-5-CHANGED: CAPWAP changed state to DOWNXmodem file
system is available.
flashfs[0]: 12 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 6878208
flashfs[0]: Bytes available: 9120768
flashfs[0]: flashfs fsck took 30 seconds.
Base ethernet MAC Address: 00:15:63:eb:d3:d2
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1240-k9w8-mx.124-23c.JA2/c1240-k9w8-mx.124-23c.JA2"...#########
File "flash:/c1240-k9w8-mx.124-23c.JA2/c1240-k9w8-mx.124-23c.JA2" uncompressed a
nd installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.4(23c)JA2, RELEASE
SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 12:58 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 12 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15740928
flashfs[1]: Bytes used: 6878208
flashfs[1]: Bytes available: 8862720
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 7100 E8000000 A0000000 80000000 3
Radio1  present A506 6700 E8000100 A0040000 80010000 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1242AG-A-K9    (PowerPCElvis) processor (revision A0) with 27638K/5
120K bytes of memory.
Processor board ID FTX0948B0DV
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.116.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:15:63:EB:D3:D2
Part Number                          : 73-9925-04
PCA Assembly Number                  : 800-26579-04
PCA Revision Number                  : A0
PCB Serial Number                    : FOC0943375H
Top Assembly Part Number             : 800-26804-02
Top Assembly Serial Number           : FTX0948B0DV
Top Revision Number                  : B0
Product/Model Number                 : AIR-AP1242AG-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:06.819: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t
est passed
*Mar  1 00:00:08.234: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 0
*Mar  1 00:00:09.622: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 1
*Mar  1 00:00:09.703: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log
(contains, 1024 messages)
*Mar  1 00:00:09.734:  status of voice_diag_test from WLC is false
*Mar  1 00:00:11.836: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar  1 00:00:11.894: %SYS-5-RESTART: System restarted --
SOFTWARE (fc3)
*Mar  1 00:00:11.895: %SNMP-5-COLDSTART: SNMP agent on host AP0015.63eb.d3d2 is
undergoing a cold start
*Mar  1 00:00:11.974: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:12.155: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:12.155: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:12.155: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:12.395: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Mar  1 00:00:12.395: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:00:12.754: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power s
ource
*Mar  1 00:00:12.842: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
*Mar  1 00:00:13.159: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
1, changed state to down
*Mar  1 00:00:13.182: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:13.650: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:14.183: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:14.195: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:20.279: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned D
HCP address 10.214.10.64, mask 255.255.255.0, hostname AP0015.63eb.d3d2
*Mar  1 00:00:30.837:  status of voice_diag_test from WLC is false
*Mar  1 00:00:30.993: Logging LWAPP message to 255.255.255.255.
Translating "CISCO-CAPWAP-CONTROLLER.atg.local"...domain server (10.214.10.10)
Translating "CISCO-LWAPP-CONTROLLER.atg.local"...domain server (10.214.10.10)
If you need anything else, let me know.
I have recently attempted to install a new IOS on the AP assuming that it was in lightweight AP, off of a LAN controller. I was successful at getting the IOS to flash, however I am unable to boot from it at this time. Am I on the right track of it being a lightweight AP at the moment?
I am glad to see I am on the right track. There is a slight problem though. I have not been able to flash the firmware. I have done the following steps:
Loaded a TFTP program on a computer the AP is connected with
Set the Computer's IP address to 10.0.0.2/24
Renamed the IOS file to c1240-k9w7-tar.default
Unplugged the AP and held the mode button upon reboot
Watched as the AP would not download the file but connected to the computer to trigger the TFTP software
What do you see that I am doing wrong so far? I am shortly going to try to do this off of a different computer with XP on it.
Jordan,
The mode button needs to be held down for 20 to 30 seconds until the status LED light is red.
A message will also be in the AP log indicating that the mode button is being held down.
Bill Jenkins
Bill,
I think there was a firewall problem in uploading the IOS from the TFTP server. I was able to successfully get the image on the AP. I thank you for all your help.
Jordan
Hi.
i have a AIR-AP1242AG-a-K9 but present a problem:
After load de firmware display the next messegaes
*Jun 25 21:49:55.936: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Jun 25 21:50:05.936: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
Not in Bound state.
*Jun 25 21:50:15.936: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Jun 25 21:50:15.938: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Jun 25 21:50:25.939: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Jun 25 21:50:35.939: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Jun 25 21:50:45.939: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
User Access Verification
Username: admin
Password:
% Authentication failed
some ideas?
