02-19-2013 06:58 PM - edited 07-03-2021 11:34 PM
Hi all,
yesterday I have my AIR-AP1252AG-C-K9 failed, I cannot access it via IP and I also cannot find it via CDP.
when i connect the power, the ethernet and radio lights go to red and status light goes orange/amber immediately and keep this all the time. see the attached pic.
if i try to hold the mode button from when i connect the power, all three lights keep off and never be on unless you leave the mode button along and re-connect the power.
and there is NO output from the sierial console.
any idea on what is the problem and how to fix it?
thank you very much.
Solved! Go to Solution.
02-19-2013 07:00 PM
You need to RMA the device. Nothing else you can do.
02-19-2013 07:00 PM
02-19-2013 07:02 PM
thank you very much for your quick reply, but what is RMA?
02-19-2013 07:14 PM
You open a tac case and you request a RMA or a "return merchandise authorization". They will replace the AP.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
