AIR-AP1572EAC-E-K9 dosen't work fine
Luigi Gnerre
Hello everone,
I have a problem on seven external (campus external) AP.
This AP doesn’t reach the captive portal but the internal campus working fine
The difference between the external and internal AP is:
  • Model
    • AIR-AP1572EAC-E-K9 for external AP
  • AP Mode
    • Flex connect for external AP
    • Local for internal
The wlc version is 17.3.2a
Someone have an idea where is the issue?
Luigi
marce1000
      >...This AP doesn’t reach the captive portal but the internal campus working fine
  - The above sentence is a bit confusing   , APs don't use the captive portal themselves ,
 M.
Prince.O
As @marce1000 stated , your sentence is a bit confusing as the clients are the ones that get the captive portal. With that being said , i'm guessing you are stating that clients cant get the captive portal outside on the outdoor Ap , but the indoor clients work fine .
Since the outdoor Aps are in flexconnect mode, one thing to confirm is are the indoor and outdoor Aps using the same policy profile ?
- If it is different , what is the settings on the policy profile for the flexconnect Aps ?
- What DNS servers are the clients outdoor getting vs. indoor clients ?
Rich R
1. Update your software as per TAC recommended below.
2. As @marce1000 usually likes to remind people - use the output from "show tech wireless" to check your config on https://cway.cisco.com/wireless-config-analyzer/
3.  Have you done a radioactive trace on a client trying to connect to one of the external APs to understand what stage it is failing at?  A packet capture can also be useful.
