AIR-AP1852I as standalone
joaopaulosl
Recently I bought an AIR-AP1852I to use in my office.
I have never had a Cisco product before. We always had some cheap consumer APs before.
I connected the AP to the energy, and connected the POE port to a switch on my network.
The AP started showing the colors green, red and amber, I was waiting to appear a CiscoAirProvision SSID on Wifi
but did not appear.
I did some research and found that my AP is probably in Lightweight mode. For it to work as
standalone, I would have to convert it to use Cisco Mobility Express Software and that this has to be done via line
of command.
My question is, what procedures do I have to do to get access to the AP via the command line?
I even got to see what the ip DHCP gave to the AP, I can ping the IP of the AP, but I can not connect via telnet.
 To get started, console cable and an autonomous AP image.
 From that point on, there are planty of guide on the internet or you can ask here.
-If I helped you somehow, please, rate it as useful.-
