AIR-AP280
kjefferson1
We have an AIR-AP280 that can not be seen by Cisco 5520 Wireless Controller.
Fas 0/1 178 R T AIR-AP280 Gig 0
interface FastEthernet0/1
description cisco AP
switchport access vlan 512
switchport mode access
switchport voice vlan 11
mls qos trust dscp
spanning-tree portfast
spanning-tree bpduguard enable
Vlan512 is up, line protocol is down
Hardware is EtherSVI, address is a0cf.5baf.a7c3 (bia a0cf.5baf.a7c3)
Description: Wireless-MGNT
Internet address is 10.40.12.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input 01:11:25, output 01:11:08, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
25897 packets input, 6382358 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
27244 packets output, 1743616 bytes, 0 underruns
0 output errors, 0 interface resets
MPC-MV3-IDF1-QA#show interfaces fa0/1
FastEthernet0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is a0cf.5baf.a783 (bia a0cf.5baf.a783)
Description: cisco AP
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
5 minute input rate 2000 bits/sec, 1 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
605831 packets input, 128264808 bytes, 0 no buffer
Received 601134 broadcasts (570624 multicasts)
0 watchdog, 570624 multicast, 0 pause input
753478 packets output, 62894860 bytes, 0 underruns
16 Replies 16
Like Leo pointed out the power output is not the problem why the AP is not joining the WLC.
Post the complete output to the command "sh cdp n F0/1 det". I want to know if the AP is getting a valid IP address or not.
