AIR-AP2802I-E-K9 Factory Reset
danielryan172
I brought a used AIR-AP2802I-E-K9, I plugged it in and it didn't work so i purchased a power injector. I have now got it to power up. After it finished its little boot the leds flash green red and blue constantly. The SSID isn't visible. Could this be reset to factory settings?
Thanks in advance
Scott Fella
Here is a document that goes over the led status: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/2800/quick/guide/ap2800iegetstart.html#pgfId-69305
What you should do is console into the ap and see what the output is showing you.
-Scott
Just to add, since you bought it used, you don't know if the image is for Mobility Express or if its lightweight in which you need a WLC. The problem with getting a used AP is that you will not be able to download an image which you might need unless you already have a support contact that allows you to download.
-Scott
Leo Laohoo
As what Scott said, I suspect the AP is loaded with CAPWAP image.
