AIR-AP2802I-E-K9
Heinz
Good Day,
How do I un-shut below?
I do not see the option on the WLC nor doing a ? in the CLI
wifi0 unassigned unset administatively down down n/a
wifi1 unassigned unset administatively down down n/a
marce1000
 - Can you check , if the involved APs can effectively join the controller ?
 M.
Good Day,
AP do join the WLC - issue is/was not enough PoE to power up the internal radios of the AP - PoE injector used & problem solved.
