05-13-2017 05:16 PM - edited 07-05-2021 07:01 AM
i have this new Access Point air-ap2802i-i-k9 with two ports (Ethernet & AUX) and i want to connect both of them as port-channel and connect them
to Switch ,so what is the configuration suppose to do on this Access Point as it is Lightweight and there is no configuration done on its IOS S/W
Solved! Go to Solution.
05-14-2017 12:45 AM
What switch are you plugging it into? According to this it has to be a 3650/3850/4500/6500
Cheers,
Ric
05-14-2017 12:45 AM
Cheers,
Ric
05-14-2017 01:30 AM
have 3650 switch and compatible with access points , i am asking about the configuration , do i have to configure only from switch side ? Or do configuration from both sides
05-14-2017 01:57 AM
It should work automatically. Just connect the ports. autonegotiation will form the etherchannel.
05-14-2017 12:46 AM
Salam Mohamed,
The auto-port channel with this AP is only supported with specific switch models. that are:
This is what Cisco documents specify. So, if you don't have one of the above models, I am not sure if it will work. But you try to put the port channel ON (no negotiation) and try if it works.
Amjad
05-14-2017 01:30 AM
I have 3650 switch and compatible with access points , i am asking about the configuration , do i have to configure only from switch side ? Or do configuration from both sides
05-15-2017 01:09 AM
One search with google and I found a helpful document with configuration included:
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-3800-series-access-points/200898-Link-aggregation-on-1800-2800-3800-AP.pdf
Good luck!
