AIR-CAP 1702i standalone, is it possible to use different DHCP pools with different interfaces.
kotobeg
I have WiFi AP AIR-CAP 1702. I can configure DHCP pool on it to activate DHCP server. Is it possible to use different pools, with different IP networks, for 2.4 and 5 GHz respectively?
2 Accepted Solutions
marce1000
- Not possible.
 M.
Rasika Nayanajith
if you have a L3 switch to connect this AP, then you can pass multiple vlans to different SSID configured on the AP.
Since AP is L2 device, you cannot route multiple vlan traffic within AP itself.
Rasika
*** Pls rate all useful responses ***
marce1000
- Not possible.
 M.
Can i ask one q i have converted 1702i ap all i ok but when i go on gui and try to save anything they give me error 404 not found
Rasika Nayanajith
Rasika
Thanks!!!!
