10-08-2012 08:34 AM - edited 07-03-2021 10:47 PM
I am trying to pass a WCS AP Template to my Test Mesh Root AP, when I try and apply the template, I get the following error:
Failure: MEDIATION-1,Attempt to set conflicting attribute value,LradIf,adminStatus,LradIf! followed by the mac address.
This is the first attempt to try and set a mesh Root AP up, any help would be appreciated.
thanks
nev
10-08-2012 12:02 PM
Depends on what the template is doing. To start, make sure the ap ethernet and radio interfaces are admin enabled and up. Check that you have whatever power source you are using (ac/poe injector) configured.
10-09-2012 12:45 AM
Hi Matt
The Interfaces are up and Admin enabled, but I cant get the radio interfaces up, comes back with errors. This is my first attempt to teast a mesh. I have the AP powerd over ethernet on a 3750x with dual power supplies.
