Showing results forĀ
Search instead forĀ
Did you mean:Ā
AIR-CAP1602I-E-K9 Not Talking to WLC 5508
johnlloyd_13
Level 9
Level 9
hi all,
can't seem to get my APs to talk to WLC 5508.
can someone advise which WLC firmware to use and where can i get/download (link pls).
currently WLC is running 6.0.199.4.
Mar  1 00:00:47.839: %CDP_PD-4-POWER_OK: All radios disabled - NEGOTIATED inlin
e power source
*Mar  1 00:00:53.931: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:00:55.963: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addre
ss 172.28.159.15, mask 255.255.255.192, hostname APfc99.47a3.4d22
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:01:06.899: %CAPWAP-3-ERRORLOG: Did not get log server settings from D
HCP.
*Mar  1 00:01:15.899: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROL
LER
*Mar  1 00:01:15.899: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_f8
:72:64'running version 6.0.199.4 is rejected.    <<<<
APfc99.47a3.4d22>sh ve
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.2(2)JB, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 04:52 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFT
WARE (fc1)
APfc99.47a3.4d22 uptime is 11 minutes
System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-E-K9    (PowerPC) processor (revision B0) with 98294K/32768K
bytes of memory.
Processor board ID FGL1726W6DQ
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.4.1.37
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: FC:99:47:A3:4D:22
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17182J4J
Top Assembly Part Number             : 800-38552-01
Top Assembly Serial Number           : FGL1726W6DQ
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1602I-E-K9
Configuration register is 0xF
Sandeep Choudhary
HI John,
You have WLC version 6.0.199.4.
CAP 1602I AP minimum requirement is to have 7.4.100.0 version on WLC.
So you must upgarde the WLC version to atleast 7.4.100.0 then only AP can join to your WLC.
Here is the compatibilty matrix:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Dont forget to rate helpful posts
17 Replies 17
Sandeep Choudhary
HI John,
Thanks for the link! Didn't see that when I was searching earlier. Will keep this with me.
We managed to upgrade 6.0 > 7.0 > 7.4 and works like a charm. Still getting my feet wet with wireless. Awesome stuff!
Hi!
I have the same problem, upgrade the WLC but now does not recognize the license and not support any APs
I must do?
Juan luis
Paste the output from wlc: sh sysinfo
From AP: sh version
also paste the log from AP ?
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.100.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... WLC-CAMP
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.2.3.230
Last Reset....................................... Software reset
System Up Time................................... 3 days 23 hrs 38 mins 23 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +39 C
External Temperature............................. +22 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 6C:41:6A:5F:95:20
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 0
I sent the initialization of AP:
IOS Bootloader - Starting system.
FLASH CHIP: Micronix MX25L256_35F
Xmodem file system is available.
flashfs[0]: 5 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31936000
flashfs[0]: Bytes used: 6551040
flashfs[0]: Bytes available: 25384960
flashfs[0]: flashfs fsck took 9 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 4c:00:82:9a:47:a3
************* loopback_mode = 0
Loading "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"...####################
File "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx" uncompressed and installed, entr
y point: 0x100000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
SOFTWARE (fc1)
Initializing flashfs...
flashfs[2]: 5 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31808000
flashfs[2]: Bytes used: 6551040
flashfs[2]: Bytes available: 25256960
flashfs[2]: flashfs fsck took 9 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 1 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
memory validate-checksum 30
% Invalid input detected at '^' marker.
no ip http server
login authentication default
export@cisco.com.
Warning:  the compile-time code checksum does not appear to be present.
cisco AIR-CAP1602I-N-K9    (PowerPC) processor (revision B0) with 98294K/32768K
bytes of memory.
Processor board ID FGL1730S57A
Base ethernet MAC Address: 4C:00:82:9A:47:A3
PCB Serial Number                    : FOC17284HL9
Top Assembly Serial Number           : FGL1730S57A
Product/Model Number                 : AIR-CAP1602I-N-K9
% Please define a domain-name first.
logging facility kern
logging trap emergencies
Press RETURN to get started!
*Mar  1 00:00:12.451: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. In
itialising Cfg
*Mar  1 00:00:13.683: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar  1 00:00:14.687: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
*Mar  1 00:00:15.123: %SYS-5-RESTART: System restarted --
SOFTWARE (fc1)
*Mar  1 00:00:15.151: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. In
itialising Cfg
*Mar  1 00:00:15.151: %CAPWAP-3-ERRORLOG: Failed to load configuration from flas
h. Resetting to default config
*Mar  1 00:00:16.195: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to uplwapp_crypto_init: MIC Present and Parsed Successfully
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact pe
rformance
*Mar  1 00:00:46.971: %CDP_PD-4-POWER_OK: All radios disabled - INJECTOR_CONFIGU
RED_ON_SOURCE inline power source
*Mar  1 00:00:51.999: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addre
ss 10.2.3.100, mask 255.255.255.0, hostname AP4c00.829a.47a3
Translating "CISCO-CAPWAP-CONTROLLER.campeche.ecosur.mx"...domain server (10.2.3
.10) [OK]
*Mar  1 00:01:02.971: %CAPWAP-3-ERRORLOG: Did not get log server settings from D
HCP.
HI Juan,
bytes of memory.
You have country set US on WLC.
And Your AP country regulation shows as -N-.
For US you must have -A- regulaterd domain on AP.
Whcih country you are in ???
I am in Mexico
HI Juan,
Change the country code on WLC.
GUI:
Disable both Network first
Choose Wireless > 802.11a/n > Network, Unselect the 802.11a Network Status check box.,Click Apply
Choose Wireless > 802.11b/g/n > Network.,Unselect the 802.11b/g Network Status check box.,Click Apply
Wireless > Country and there you can change the county.
After changing the Country you must enable both networks again.
CLI:
Change the country code of a WLC, you must disable the 802.11a and 802.11b network :
>config 802.11a disable network
>config 802.11b disable network
Now you can change the country code of the controller. For example, we change it from US to Mexico
>config country MX (Mexico)
After changing the country,enable the 802.11 interfaces.
>config 802.11a enable network
>config 802.11b enable network
Thank you, this change resolved the problem of the WLC licenses.
However, even the WLC not recognize the APs, I hit the error here:
itialising Cfg
to up
SOFTWARE (fc1)
itialising Cfg
rformance
*Mar  1 00:00:46.391: %CDP_PD-4-POWER_OK: All radios disabled - INJECTOR_CONFIGU
*Mar  1 00:00:48.927: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addre
.10) [OK]
*Mar  1 00:00:59.875: %CAPWAP-3-ERRORLOG: Did not get log server settings from D
HCP.
*Mar  1 00:01:09.875: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 28 16:01:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 10.2.3.230 peer_port: 5246
*Jan 28 16:01:06.531: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
peer_ip: 10.2.3.230 peer_port: 5246
*Jan 28 16:01:06.531: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 28 16:01:06.535: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination
*Jan 28 16:01:06.535: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
essage type 10 state 5.
*Jan 28 16:01:06.535: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Jan 28 16:01:06.535: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap pac
ket from 10.2.3.230
*Jan 28 16:01:11.531: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 28 16:02:05.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
2.3.230:5246
*Jan 28 16:02:05.999: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta
te 255
*Jan 28 16:02:05.999: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. In
itialising Cfg
*Jan 28 16:02:05.999: %CAPWAP-3-ERRORLOG: Failed to load configuration from flas
*Jan 28 16:02:16.015: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 28 16:02:16.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jan 28 16:02:16.535: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jan 28 16:02:16.535: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 28 16:02:16.535: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination
*Jan 28 16:02:16.535: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
*Jan 28 16:02:16.535: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Jan 28 16:02:16.535: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap pac
ket from 10.2.3.230
*Jan 28 16:02:21.535: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 28 16:03:15.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
2.3.230:5246
*Jan 28 16:03:15.999: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta
te 255
*Jan 28 16:03:15.999: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. In
itialising Cfg
*Jan 28 16:03:15.999: %CAPWAP-3-ERRORLOG: Failed to load configuration from flas
*Jan 28 16:03:26.011: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 28 16:03:26.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jan 28 16:03:26.539: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jan 28 16:03:26.539: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 28 16:03:26.539: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination
*Jan 28 16:03:26.539: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
*Jan 28 16:03:26.539: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Jan 28 16:03:26.539: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap pac
ket from 10.2.3.230
*Jan 28 16:03:31.539: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
regards
Make sure the time is set properly on the WLC or else the AP will not join.  Also make sure the country domain of the AP is defined on the WLC.  Post the entire output from the console of the AP from when you power cycle the access point.
Also Accept Self Signed Certificate (SSC) under Security/AP policy.
Paste the output of this command: debug lwapp events enable    or         debug capwap events enable
Date and time is ok on the WLC,
I configured Accept Self Signed Certificate (SSC) under Security / AP policy, once done the WLC recognized the AP, but output from the console of the AP  power cycle the access point is:
y point: 0x100000
executing...
           cisco Systems, Inc.
SOFTWARE (fc1)
no ip http server
export@cisco.com.
bytes of memory.
itialising Cfg
to up
SOFTWARE (fc1)
itialising Cfg
rformance
*Mar  1 00:00:48.695: %CDP_PD-4-POWER_OK: All radios disabled - INJECTOR_CONFIGU
*Mar  1 00:00:48.923: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addre
.10) [OK]
*Mar  1 00:00:59.915: %CAPWAP-3-ERRORLOG: Did not get log server settings from D
HCP.
*Mar  1 00:00:59.919: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is
not established. A0203E6, 147E, A020364, A47B, 0
*Mar  1 00:01:09.915: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 29 09:33:18.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jan 29 09:33:18.535: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jan 29 09:33:18.535: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 29 09:33:23.535: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 29 09:34:17.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
2.3.230:5246
*Jan 29 09:34:17.999: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta
te 255
*Jan 29 09:34:17.999: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. In
itialising Cfg
*Jan 29 09:34:17.999: %CAPWAP-3-ERRORLOG: Failed to load configuration from flas
*Jan 29 09:34:28.015: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 29 09:34:28.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jan 29 09:34:28.535: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jan 29 09:34:28.535: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 29 09:34:33.535: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
and debug command output enable CAPWAP events
(Cisco Controller) >debug capwap events enable
(Cisco Controller) >*spamApTask7: Jan 29 03:39:08.092: acDtlsPlumbControlPlaneKeys: lrad:10.2.3.100(42107) mwar:10.2.3.230(5246)
*spamApTask7: Jan 29 03:39:08.093: 4c:00:82:9a:47:a0 DTLS keys for Control Plane deleted successfully for AP 10.2.3.100
*spamApTask7: Jan 29 03:39:08.100: 4c:00:82:9a:47:a0 DTLS connection closed event receivedserver (10.2.3.230/5246) client (10.2.3.100/42107)
*spamApTask7: Jan 29 03:39:08.100: 4c:00:82:9a:47:a0 Entry exists for AP (10.2.3.100/42107)
*spamApTask7: Jan 29 03:39:08.100: 4c:00:82:9a:47:a0 No AP entry exist in temporary database for 10.2.3.100:42107
*spamApTask7: Jan 29 03:39:08.104: 4c:00:82:9a:47:a0 Discovery Request from 10.2.3.100:42107
*spamApTask7: Jan 29 03:39:08.104: 4c:00:82:9a:47:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 500, joined Aps =0
*spamApTask7: Jan 29 03:39:08.104: apModel:
*spamApTask7: Jan 29 03:39:08.104: apType = 38 apModel:
*spamApTask0: Jan 29 03:39:08.105: 4c:00:82:9a:47:a3 Received LWAPP DISCOVERY REQUEST to 6c:41:6a:5f:95:2f on port '13'
*spamApTask0: Jan 29 03:39:08.105: 4c:00:82:9a:47:a3 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask7: Jan 29 03:39:08.105: 4c:00:82:9a:47:a0 Discovery Response sent to 10.2.3.100 port 42107
*spamApTask7: Jan 29 03:39:08.105: 4c:00:82:9a:47:a0 Discovery Response sent to 10.2.3.100:42107
*spamApTask7: Jan 29 03:39:08.105: 4c:00:82:9a:47:a0 Discovery Request from 10.2.3.100:42107
*spamApTask7: Jan 29 03:39:08.105: 4c:00:82:9a:47:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 500, joined Aps =0
*spamApTask7: Jan 29 03:39:08.105: apModel:
*spamApTask7: Jan 29 03:39:08.105: apType = 38 apModel:
*spamApTask7: Jan 29 03:39:08.106: 4c:00:82:9a:47:a0 Discovery Response sent to 10.2.3.100 port 42107
(Cisco Controller) >*spamApTask7: Jan 29 03:39:08.106: 4c:00:82:9a:47:a0 Discovery Response sent to 10.2.3.100:42107
*spamApTask7: Jan 29 03:39:18.104: 4c:00:82:9a:47:a3 DTLS connection not found, creating new connection for 10:2:3:100 (42107) 10:2:3:230 (5246)
*spamApTask7: Jan 29 03:39:18.638: acDtlsPlumbControlPlaneKeys: lrad:10.2.3.100(42107) mwar:10.2.3.230(5246)
*spamApTask7: Jan 29 03:39:18.638: 4c:00:82:9a:47:a3 Allocated index from main list, Index: 397
*spamApTask7: Jan 29 03:39:18.638: 4c:00:82:9a:47:a3 Using CipherSuite AES128-SHA
*spamApTask7: Jan 29 03:39:18.638: 4c:00:82:9a:47:a3 DTLS keys for Control Plane are plumbed successfully for AP 10.2.3.100. Index 398
*spamApTask6: Jan 29 03:39:18.638: 4c:00:82:9a:47:a3 DTLS Session established server (10.2.3.230:5246), client (10.2.3.100:42107)
*spamApTask6: Jan 29 03:39:18.638: 4c:00:82:9a:47:a3 Starting wait join timer for AP: 10.2.3.100:42107
*spamApTask7: Jan 29 03:39:23.636: 4c:00:82:9a:47:a0 Join Request from 10.2.3.100:42107
*spamApTask7: Jan 29 03:39:23.636: 4c:00:82:9a:47:a3 Deleting AP entry 10.2.3.100:42107 from temporary database.
*spamApTask7: Jan 29 03:39:23.637: 4c:00:82:9a:47:a0 MIC AP is not allowed to join by config
*spamApTask7: Jan 29 03:39:23.637: 4c:00:82:9a:47:a0 Join Request failed!
From the debug it seems as if  WLC may be authorizing Lightweight APs via anAuth-list or AAA.
Check these settings here:
Web GUI > Security > AAA > AP Policies
Seems as if your AP's are set to be authorized via an auth-list or AAA,
Try unchecking the following option:
Authorize MIC APs against auth-list or AAA
The WLC AP recognizes me, however, from the WLC did not apply the changes to the AP, such as Ap name or Location
and constantly sends this error on the console:
*Jan 29 10:48:50.531: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 29 10:49:44.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
2.3.230:5246
*Jan 29 10:49:44.999: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta
te 255
*Jan 29 10:49:44.999: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. In
itialising Cfg
*Jan 29 10:49:44.999: %CAPWAP-3-ERRORLOG: Failed to load configuration from flas
*Jan 29 10:49:45.011: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is
*Jan 29 10:49:55.011: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 29 10:49:55.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jan 29 10:49:55.535: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jan 29 10:49:55.535: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
*Jan 29 10:50:00.535: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.3.230
Do you have teamviewer on your laptop, let me see online.(If you want then only). send me ur iD and password for teamviewer in private message .
