Showing results forĀ
Search instead forĀ
Did you mean:Ā
AIR-CAP1602I-E-K9 Not Talking to WLC 5508
johnlloyd_13
Level 9
Level 9
hi all,
can't seem to get my APs to talk to WLC 5508.
can someone advise which WLC firmware to use and where can i get/download (link pls).
currently WLC is running 6.0.199.4.
Mar  1 00:00:47.839: %CDP_PD-4-POWER_OK: All radios disabled - NEGOTIATED inlin
e power source
*Mar  1 00:00:53.931: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:00:55.963: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addre
ss 172.28.159.15, mask 255.255.255.192, hostname APfc99.47a3.4d22
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:01:06.899: %CAPWAP-3-ERRORLOG: Did not get log server settings from D
HCP.
*Mar  1 00:01:15.899: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROL
LER
*Mar  1 00:01:15.899: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_f8
:72:64'running version 6.0.199.4 is rejected.    <<<<
APfc99.47a3.4d22>sh ve
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.2(2)JB, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 04:52 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFT
WARE (fc1)
APfc99.47a3.4d22 uptime is 11 minutes
System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-E-K9    (PowerPC) processor (revision B0) with 98294K/32768K
bytes of memory.
Processor board ID FGL1726W6DQ
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.4.1.37
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: FC:99:47:A3:4D:22
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17182J4J
Top Assembly Part Number             : 800-38552-01
Top Assembly Serial Number           : FGL1726W6DQ
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1602I-E-K9
Configuration register is 0xF
17 Replies 17
I think you must accept MIC to get connecto from AP.
Hope next time you will remeber this.
Dont forget to rate helpful posts
Than you Sandeep
Everything worked well
Hi Sandeep , M having issue like When i shift AP from one 2504 WLC to another 2504 WLC its having problem to rejoin . What the solution for the same
