AIR-CAP3502I-A-K9 | I am not able to get into username/password prompt
Ibrahim Jamil
Level 6
Level 6
Hello Guys
I have AIR-CAP3502I-A-K9   I  am not able to get into username/password prompt ,even when i press Enter , didnt get me there
i need to learn how to join this AP Manulay to WLC
can u pls help
thanks
Scott Fella
On the console you should get a prompt in which the default is Cisco/Cisco. If you don't get a prompt, then look at the image when the AP boots.
In order to manually configure static information on a LAP using the AP CLI interface, you can use these EXEC mode CLI commands:
AP#capwap ap ip address
AP#capwap ap ip default-gateway
AP#capwap ap controller ip address
AP#capwap ap hostname (optional)
-Scott
Hello Scott
this AP Wont le me get into Prompt , it keeps asks for WLC , i lost my way to get to #Prompt:(
thanks
