air-cap3502i-e-k9 led stop working.
apmari
Hi there,
i've one of my 3500 that when finish to download the os, the front led stop working.
During the power on and all the test the led is flashing in various colors pretty ipnotizing
When it bacame operative, the led stops.
If i issue the test led flashing console command it works.
Any suggestion?
apm
Hamilton.tom
Reset the access point back to default. You can do this VIA the controller or by holding the mode button.
I also suggest confirming this command has not been issued
(Cisco Controller) config>ap led-state disable all
Tom
