AIR-CAP3502I-E-K9 Modulation issue (I quess)
RokasK
Hi everyone
i have AIR-CAP3502I-E-K9 as stand alone connected to my cisco isr and the maximum speed I can achieve is about 47mbps on 802.11n . I tried setting different modulation and channel width, inreasing antenna power etc. and nothing! below is my wifi's configuration. Please dont judge me hard on password
Help me if you can thanks
Building configuration...
Current configuration : 1916 bytes
! Last configuration change at 22:24:21 UTC Sat Jul 20 2002
version 15.3
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$GJ/o$E3vGE99HO8BSmiMRY2m/x0
no aaa new-model
no ip source-route
no ip cef
ip name-server 8.8.8.8
dot11 pause-time 100
dot11 syslog
dot11 ssid aironet
vlan 3
authentication open
no ipv6 cef
username Cisco password 7 1531021F0725
bridge irb
interface Dot11Radio0
no ip address
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
bandwidth 6000000
no ip address
ssid aironet
antenna gain 0
peakdetect
no dfs band block
speed basic-48.0 m15.
channel width 40-above
channel 5680
station-role root
interface Dot11Radio1.3
bandwidth 6000000
encapsulation dot1Q 3 native
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.3
bridge-group 1
interface BVI1
mac-address e8b7.4859.e8d1
bandwidth 6000000
ip address dhcp client-id GigabitEthernet0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
8 Replies 8
Rasika Nayanajith
What client are you using for testing?
AAP1#show dot11 associations <mac_addr>
I noticed you statically set channel to 136 [5680], is there a reason for it? Also you set 48Mbps is the basic rate, that mean your client has to be very close to the AP to maintain WiFi connectivity. If this is a home environment, I would not set like that aggressive. At least make 12 Mbps or 24Mbps basic and allow all other MCS rates. (remove that specific speed command & test it again)
channel 5680
Rasika
*** Pls rate all useful responses ***
The reason why I tried to do only two modulations is because I expected that only with the highest troughout put I will achieve desired speed.
By the way it is clode to one each other but the speed is still 45mbit maximum.
ap#show Dot11 associations
802.11 Client Stations on Dot11Radio0:
SSID [aironet] :
MAC Address IP address IPV6 address Device Name
Parent State
645a.04af.c162 192.168.3.3 :: unknown -
self Assoc
f62d.b82d.c0ec 192.168.3.2 :: unknown -
self Assoc
Pls get "show dot11 association 645a.04af.c162" output to see on what RSSI/SNR client get. I would suggest keep that AP on the table & see any difference as the signal may not come properly as it is stuck under that switch.
Rasika
Hi every one how we download the frimware of cisco access point air cap3502i mode autonmouse .please help me
You download it from the software download section on Cisco’s website. You need to have a support contract for one, and if the image or model is not showing on the downloads, then the ap is no longer supported and Cisco has pulled it. The only way you will find that is just searching on the internet to see if anyone has it.
-Scott
Hi dear
Ok I searching this version firmware and i find it in the Cisco software
but I can't download the frimware
The Cisco.Com shows a message it is
You must have a valid servise contract associated to your cisco.com profile
What I doing to this?
Please help me
you need a firmware or operation system?
Hi engineer
I need firmware mode autonomous to cisco access point air cap3500i because
I didn't have a Wireless LAN Controller.
If be passable sent me the image of firmware autonomous please.
