AIR-CAP3702E-A-K9 Antennas
Fahad Siddiqui
Hi I looked around on the forums wasnt able to find the answer to my question. Can you operate a 3702E without external antennas?
Sandeep Choudhary
NO..
As you can see its name says that it is an AP with external antenna.
3702E-> EXTERNAL
Dont forget to rate helpful posts
Talked to Cisco TAC. They said it is possible to use the AP without antennas, but isn't recommended.
