08-21-2014 08:09 AM - edited 07-05-2021 01:24 AM
I have a 5508 WLC with the 7.6.120.0 Software Version. I connect some new, out-of-the-box AIR-CAP3702E-A-K9 AP's and they show:
CleanAir Admin Status = Enable
CleanAir Oper Status = DOWN
When I go to the "Wireless" Tab, then to "Radios" on the menu and select "Configure" on the AP, CleanAir Admin Status is on "Enable."
Does this mean that the AP is doing the CleanAir?
Thank you in advance.
08-21-2014 08:32 PM
Is CleanAir enabled GLOBALLY?
Wireless > 802.11a > CleanAir and is it ticked?
08-27-2014 02:17 PM
Please refer: http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_010000101.html
Hope that helps.
