AIR-CT5760 - Wireless controller , logout issue
     we had updated latest os (03.06.03.E RELEASE SOFTWARE (fc3) to AIR-CT5760 wireless controller recently.
     The problem is after updated i am not able see logout option in the webpage view.
      What could be the issue? what is the trouble shoot?
Bala
Philip D'Ath
Meraki Community All-Star
Have you tried a different web browser?
Probably a bug if the issue did not happen before.  You are on a gold star release, so if that is the only problem I wouldn't worry about it.
Hi,Thanks for your reply, I tried on some other browser also. But still problem persist.
I always use CLI for my 5760. But looked GUI to see after seen this post.
Yes, I can confirm there is no logout button in my 5760 with 3.6.3E.
Rasika
Even, mac address disable option also not available in GUI after upgrade.
Previously it was available.
