AIR-LAP1141-A-k9 continuely reboots
John Trumbell
I have an AIR-LAP1141-A-K9 it keeps rebooting itself. It seems to boot up and loads the flash and then shortly afterwards and before I get to console login it reboots.in reviewing what I've captured from the boot process is a message "Unexpected exception to CPUvector 200, PC = 1020" Below it is the following "Traceback - 0x1020 0x51351c 0x51351c 0x513c00 0x4FB1A8 0x4FB5B0 0x4F7FB8 0x191214 0x1912c8 0x57090 0x57398 0x1A5E50"  I tried a couple google searches but didn't have any luck finding anything that matched what I have occuring.
Any ideas?
John
5 Replies 5
Leo Laohoo
Power down the WAP.
Console into the WAP.
Power up the WAP.
Post the entire bootup process up to the point the WAP will crash.
Here's the capture from console,
flashfs[1]: 27 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 7432192
flashfs[1]: Bytes available: 24694784
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
00:00:07 UTC Fri Mar 1 2002: Unexpected exception to CPUvector 200, PC = 0x512AC4  , LR = 0x51351C
-Traceback= 0x512AC4 0x51351C 0x513C00 0x4FB1A8 0x4FB5B0 0x4F7FB8 0x191214 0x1912C8 0x57090 0x57398 0x1A5E50
CPU Register Context:
MSR = 0x00029230  CR  = 0x24000028  CTR = 0x004FB0DC  XER   = 0x00000000
R0  = 0x9400AE16  R1  = 0x012D7E30  R2  = 0x00000000  R3    = 0x012D7F50
R4  = 0x00000008  R5  = 0x012D7F60  R6  = 0x00000000  R7    = 0x012D7F48
R8  = 0x4B233FAE  R9  = 0x00000000  R10 = 0xBD912F2B  R11   = 0x009C7C72
R12 = 0x9F2E6F80  R13 = 0x01000000  R14 = 0x00000000  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23   = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x00000000  R27   = 0x00C11B1C
R28 = 0x012D7F60  R29 = 0x00000000  R30 = 0x012D7F58  R31   = 0x012D7F50
=== Flushing messages (00:00:08 UTC Fri Mar 1 2002) ===
Buffered messages:
Queued messages:
*Mar  1 00:00:09.071: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:08.944: %SYS-4-PUPDATECLOCK: Periodic Clock update with ROMMON failed, because size left in ROMMON (4294967295), size needed (29), error code (-1)
Nested exception_rom_monitor call (2 times)
Unexpected exception to CPUvector 200, PC = 512AC4
Exception (200)! Machine Check
ESR: 0x00000000, BESRA: 0x00000000, BESRB: 0x00000000, BEAR: 0xFFFFFFFF
MSR: 0x00020030, SRR2: x002B02F0,   SRR3: 0x00020030
Vector = 0x00000200  PC =  0x00512AC4  MSR = 0x00029230  CR =  0x24000028
LR =  0x0051351C     CTR = 0x004FB0DC  XER = 0x00000000
Stack trace:
PC = 0x00512AC4, SP = 0x012D7E30
Frame 00: SP = 0x012D7E40    PC = 0x00C11890
Frame 01: SP = 0x012D7EE0    PC = 0x0051351C
Frame 02: SP = 0x012D7EE8    PC = 0x00513C00
Frame 03: SP = 0x012D7F68    PC = 0x004FB1A8
Frame 04: SP = 0x012D7F88    PC = 0x004FB5B0
Frame 05: SP = 0x012D7F90    PC = 0x004F7FB8
Frame 06: SP = 0x012D7F98    PC = 0x00191214
Frame 07: SP = 0x012D7FB8    PC = 0x001912C8
Frame 08: SP = 0x012D7FD8    PC = 0x00057090
Frame 09: SP = 0x012D80E0    PC = 0x00057398
Frame 10: SP = 0x00000000    PC = 0x001A5E50
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(23c)JA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 27-Jan-12 19:37 by prod_rel_team
ap uptime is 11 seconds
cisco AIR-LAP1141N-A-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1529KF6K
PowerPC405ex CPU at 586Mhz, revision number 0x147E
using  eeprom values
WRDTR,CLKTR: 0x88000800 0x40000000
RQDC ,RFDC : 0x80000037 0x00000211
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x88000800, 0x40000000
RQDC, RFDC : 0x80000037, 0x00000211
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is NOT up.
PCIE1 port 1 not initialized
PCIEx: initialization done
flashfs[0]: 27 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7432192
flashfs[0]: Bytes available: 24952832
flashfs[0]: flashfs fsck took 21 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 44:d3:ca:03:74:43
Ethernet speed is 1000 Mb - FULL duplex
Loading "flash:/c1140-k9w8-mx.124-23c.JA4/c1140-k9w8-mx.124-23c.JA4"...######################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w8-mx.124-23c.JA4/c1140-k9w8-mx.124-23c.JA4" uncompressed and installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
Buffered messages:
Queued messages:
*Mar  1 00:00:09.069: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:08.942: %SYS-4-PUPDATECLOCK: Periodic Clock update with ROMMON failed, because size left in ROMMON (4294967295), size needed (29), error code (-1)
Stack trace:
using  eeprom values
ddr init done
Passed.
PCIE0: link is up.
executing...
enet halted
           cisco Systems, Inc.
Buffered messages:
Queued messages:
MSR: 0x00020030, SRR2: x002B02F4,   SRR3: 0x00020030
Stack trace:
using  eeprom values
ddr init done
Passed.
PCIE0: link is up.
executing...
enet halted
           cisco Systems, Inc.
Buffered messages:
Queued messages:
MSR: 0x00020030, SRR2: x002B02FC,   SRR3: 0x00020030
Stack trace:
using  eeprom values
ddr init done
Passed.
PCIE0: link is up.
executing...
enet halted
           cisco Systems, Inc.
Buffered messages:
Queued messages:
*Mar  1 00:00:09.070: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
Stack trace:
using  eeprom values
ddr init done
Passed.
PCIE0: link is up.
Thanks, but would this also include APs homing to WISM blades? Thanks
Try converting the WAP into autonomous then reconvert it back to controller-based IOS.
