air-pcm352 in ad-hoc mode dont work
mike_inang
hi, i have some problems with the air-pcm352 adapter in the ad-hoc mode with xp and sp2. after install the latest driver and after reboot i set the profile to ad-hoc, make all the other settings but i can not connect at all to the other computer.
before i install the driver and the software (different for win95) on a win95 computer, everything work fine and i could connect without any problems.
could it be that there are some problems with the SP2 ?
anyway, what can i do ?
for any help i would be very happy,
thank you already for any help.
best regards
mike
sorry but this is for LINUX. i wrote that i use winXP with the SP2. anyway thank you for the try, i found some other configuration guides for the system i use, i set all the settings like in the guide, but still i dont get any connection in ad-hoc mode. in infrastructure mode all work well. i use also a "level one" and a "d-link" pcmcia adapter, both cards work well in ad-hoc mode with my system.
well, i still need help !!!!
