09-24-2014 11:43 PM - edited 07-05-2021 01:35 AM
Hello community,
I have several AP3602i access points here and want to pair them with an AIR-RM3000M WSSM Module.
However, some of the AP do not recognize the WSSM Module (on my WLC the Radio2 module does not show up).
When looking at the console output on bootup of the AP it simply says "Radio2 not present" just as if the module is not installed.
The same module in a different AP however, works fine.
I thought of a hardware issue, but I have some 15 APs who show this behavior.
Any ideas?
Best regards
09-25-2014 01:01 AM
1. What firmware is your WLC running?
2. How are you powering your AP? PoE, PoE+, injector or power brick?
09-25-2014 01:04 AM
1. WLC is running on 7.6.130.0
2. AP is powered via external power supply. But also tested with PoE+, however showing no difference.
09-26-2014 07:35 PM
If that is the case, then what is the Regulatory Domain of your AP and what is the Regulatory Domain of your WSSI module. Both must be the same.
09-29-2014 12:21 AM
Regulatory domain of AP = DE (Germany).
I'm not sure how to find out the regulatory domain of the WSSI module?
09-29-2014 09:37 AM
What I think your regulatory domain should be "E" for both AP's and WSSI.
09-29-2014 11:21 PM
Look at the WSSI module and look at the part number. For Germany (Europe), your part number should have "-E". If not, then this is most likely where the problem is.
09-29-2014 11:53 PM
On my WSSI module the part no. is "AIR-RM3000M".
Strange enough, all of the modules I have here show this part number. There seems to be no "E" version for this module.
11-20-2014 08:16 AM
Well now, eventually I came to the bottom of this issue.
As it seems, the two screws of the need to be fully tightened with manual force until they show no further movement. I originally had them screwed in, but not far enough.
I was able to reproduce this: if one of the screws are not fully in, the module will not be recognized! Turn them fully in and it works perfect again.
So, if you come about this issue: check your screws first!
Thanks to all, who have contributed, though!
