air-sap2602i-n-k9 <=> air-cap2602i-n-k9
Chi Fai Leung
I want to order two autonomous.
What is the different between "air-sap2602i-n-k9" and "air-cap2602i-n-k9"?
Leo Laohoo
SAP means Standalone.
CAP means Controller .
But it doesn't matter if you ordered the wrong one because it is very easy to convert the AP from SAP to CAP and vice versa.
11 Replies 11
Sahil Mengi
AIR-SAP2602i-N-K9 is the PID for you, in case you want antonomous. SAP = Standalone/Ios
AIR-CAP2602i-N-K9 is the part id for unified access point intended to be used in CUWN/CA.
Best,
Sahil
Leo Laohoo
Hi Leo,
I want to use AP SAP-2600 in standalone mode now but I'll buy a controller in next year. Can I convert SAP-2600 to controller-based mode ? Does it have any problem or unstable ?
Thank you very much,
Converting from autonomous IOS to controllerb-based IOS is very easy.
All you need is to un-pack the RCV file (TAR file extension) into the AP and reboot the AP.  The AP will now boot up with controller-based IOS.
Chi Fai Leung
I saw the software of the "AIR-SAP2620I-N-K9" included "S2G1K9W7-15202JA", "S2G1K9W7-15202JB". Can tell me what different is? Thanks!
Get either "ap3g2-k9w7-tar.152-4.JA1.tar" or "ap3g2-k9w7-tar.152-2.JB2.tar".
Abhishek Abhishek
As per your query i can suggest you the following solution-
SAP stands for standalone and CAP stands for controller.
Hope this will help you.
Hi Abhishek,
I want to use aironet 2700 in autonomous mode. But I can't choose standalone model for it (with 2600 series, we have SAP-2602)
Can you help me about it ?
Scott Fella
I always thought CAP was capwap because LAP was lwapp
-Scott
Actually, it is.  I just set a "trap" to see if someone's going to do a cut-n-paste.  Looks like the trap caught one.
Is it possible to change the PID?
I have two AP, both running on autonomous IOS image 15.2(2)JB2.
AIR-SAP2602I-E-K9
AIR-CAP3602I-E-K9
Now when i want to add both to Prime Infrastructure 1.4, only the SAP is discovered correctly. The CAP is mistakenly discovered as unified AP. I think its because auf the PID.
Can anyone confirm?
Does anyone know how to resolve this?
Cheers,
Felix
