Air1220 1 antenna
ddicky
Can I use only 1 external antenna AIR-ant4941 on ap1220 to make it run?
dave.reid
Yes, you can. When doing so, you give up diversity reception, which MAY introduce problems due to multipath fade.
thisisshanky
Level 11
Level 11
Infact, the use of two antennas is to provide diversity so that multipath fading effects can be avoided. You will not get diversity with one antenna. Still it should work.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
