12-03-2020 11:50 AM - edited 07-05-2021 12:51 PM
Is it possible to have on WLC 5520 (AireOS) 2 different AP management interfaces on 2 different ports?
One port will be dedicated as an AP termination for DMZ APs first one AP management interface and the second interface assigned to the second port will be dedicated as an AP management interface for APs in LAN. for WLC management I can use interface on LAN interface.
Both of the interfaces should be routed so APs will be sitting on VLAN from a different subnet.
Thanks for the answer
regards,
Marek
Solved! Go to Solution.
12-07-2020 05:09 AM
12-03-2020 06:22 PM
You should be able to do it. You create a dynamic interface and enable AP-management on that interface.
Rasika
12-07-2020 12:51 AM
Yes I did not find any restriction on deployment guide, but since AireOS does not support any routing and there is only one ip default gateway I think it will not work, because on WLC there are 2 ports connected to 2 different networks and WLC has no idea how to reach APs on DMZ, to reach APs on lan it will use default GW, but correct me if I am wrong . And I am talking about APs sitting on different vlan not directly connected.
Marek
12-07-2020 05:09 AM
