airlap 1142 problem with existing wlc2106
buco
Hi There,
i have existing site wlc2106 with 5 APs G standard.I have problem with adding new AP 1142 N to existing configuration.
i attach output from wlc.
Any help appr.
Scott Fella
First off make sure the WLC and the ap is configured for the same country code. The best output to use is from the console of the ap. Post that output as that will explain why the ap is not joining.
-Scott
Hi Scott thx fy reply.
Same country code on both side.
Follow sample of ap console:
