Aironet 1100 AP (11.b) - am I stuck with WEP?
cisco_moron
Hi all,
I have several Aironet 1100 series access point. These are the 11.b with WEP encryption. Can I upgrade those to WPA or higher, or am I stuck with what I have?
Thanks in advance for any information.
scottmac
Level 10
Level 10
As it sits, you're probaby stuck with WEP. You can *probably* light up TKIP and make things more secure.
I believe you can upgrade the radios to newer 802.11g hardware, and get WPA capability with the higher speed (there's a hardware crypto accelerator on te G radios.
If the upgrades are available, I think they're in the neighborhood of US$100.00 or so plus/minus ...
This is off the top of my head, I haven't had (and won't have for a while) a chance to look things up for you, but this is my recollection.
Good Luck
Scott
frankzehrer
Level 4
Level 4
Hi Noel,
try out this one:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml#config_ap
This is a step by step guide for WPA2. You can not have WPA2 since the lack of a G-Radio interface. But WPA is possible.
Just change these few things:
Step 2a. Choose TKIP as Cipher
Step 3c. Tick also CCKM
I have the same setup running with 1200 APs only b Radios.
The difference is that WPA uses TKIP for encryption and WPA2 AES.
WPA2 is the modern implementation, but WPA meets the actual security needs of the most companies.
I hope that helps.
Best regards,
Frank
P.S. Please rate helpful posts.
gmercuri
Sure the 1100 supports WPA and WPA2....heres the list.
Authentication
Security Standards
? WPA
? WPA2 (802.11i)
? Cisco TKIP
? Cisco message integrity check (MIC)
? IEEE 802.11 Wired Equivalent Privacy (WEP) keys of 40 bits and 128 bits
802.1X EAP Types:
? EAP-Flexible Authentication via Secure Tunneling (EAP-FAST)
? Protected EAP-Generic Token Card (PEAP-GTC)
? PEAP-Microsoft Challenge Authentication Protocol Version 2 (PEAP-MSCHAP),
? EAP-Transport Layer Security (EAP-TLS)
? EAP-Tunneled TLS (EAP-TTLS)
? EAP-Subscriber Identity Module (EAP-SIM)
? Cisco LEAP
Encryption:
? AES-CCMP encryption (WPA2)
? TKIP (WPA)
? Cisco TKIP
? WPA TKIP
? IEEE 802.11 WEP keys of 40 bits and 128 bits
