Aironet 1200 - error in web interface
RichardMoxley
Community Member
I am attempting to configure 2 Cisco Aironet 1200 series devices for conection to an existing WLAN. Neither AP will be the Radius server.
I am able to connect to the device using IE and the IP address - however - as soon as I make any changes in any screen the screen then displays a message "Error on Page with a "!" in triangle.
This then prevents me from Applying the change asnd so configuring the device.
Anyone seen this before and know the solution - is there a bug in the web interface?
csannedhi
Level 3
Level 3
Is there an explanation along with it? Can you include a screenshot to your response? Screenshot will be helpful to diagnose the problem.
