05-22-2013 08:14 PM - edited 07-04-2021 12:07 AM
Good evening,
I have an aironet 1242, It must be connect to an DSL using a static Public IP, and this AP must provide dhcp services, could you please help me on how to configure this access point in order to be connected to Internet using Public IP and provide dhcp service.
It is a standalone access point.
05-22-2013 08:21 PM
Here is how you can setup dhcp for wireless clients. The AP will not do NAT so you will need a router connected to the dsl.
05-22-2013 10:33 PM
Looks like Scott has missed the link :-)
A typical DHCP configuration on AP would be as below.
ip dhcp pool TEST
network 192.168.61.64 255.255.255.224
default-router 192.168.61.94
lease 1
Since you have a DSL service i hope you already have a router/modem which can do NAT funtion..
Also in your case you want the AP to be configured with static public ip and hence i would assume the dhcp scope is also going to be public ip range.
Hope that helps
Najaf
Please rate when applicable or helpful !!!
05-23-2013 04:41 AM
Yeah I did forget the link:). Haha
http://www.cisco.com/en/US/docs/wireless/access_point/12.2_13_JA/configuration/guide/s13adm_ps4570_TSD_Products_Configuration_Guide_Chapter.html#wp1057097
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b.pdf#page112
05-23-2013 04:51 PM
Hello Eduar,
As per your query i can suggest you the following solution-
To configure this access point in order to be connected to Internet using Public IP and provide dhcp service.The AP can do NAT with the help of router taht is connected to DSL.
Please refer the link for more information-
Hope this will help you.
