Aironet 1562i outdoor
aswin_gbm
What will area covered by aironet 1562i with no obstruction outdoor.
Sandeep Choudhary
HI,
Try this and check:
https://www.cisco.com/en/US/docs/wireless/access_point/1550/range/calculator/1552_Link_Calculator_V1.xls
Other than that, I don't know of a coverage area table that is out there, everything is confidential and based on with survey, deployment and troubleshooting.
Dont forget to rate helpful posts
Leo Laohoo
The question is not easy to answer because there are so many factors to consider:
What is the height of the AP?
Is the AP operating in FULL power or half power?
What is the angle of the AP direction?
What band is being measured?  2.4 Ghz or 5.0 Ghz?
What data rates are enabled?
What channel width?
What is the floor noise?
Radiation pattern for the 1560I can be found HERE.
Radiation pattern for the 1560D can be found HERE.
Of course there are lots of variables. Sometimes a person is just looking for a general idea, not binding commitment. I've spent hours trying to find out if a commercial grade AP has the ability to reach 300M without screwing around with a mesh network. All I want to do is buy something that has a reasonable chance and try it. But I keep running into people that think a simple answer can't be simple.
David Murracas
This might help :)
