Aironet 1600 series
lalsingh8101
Good afternoon all,
I have a cisco aironet 1600 series , and by mistake reset this access point . But now i don't know what is the default Ip of this device. so it is a big problem for me. so anybody can suggest me default ip of this device. pls help me to configure this device.
Sandeep Choudhary
Hi Lal,
Connect AP with console cable to your laptop and set the IP then try again.
Here is the config guide:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3-JB/configuration/guide/cg_book/cg-chap3-cli.html
Don't forget to rate helpful posts
mohanak
After the access point/bridge resets, you can reconfigure the access point by using the Web-browser interface if you previously assigned a static IP address, or the CLI if you did not.
The access point is configured with the factory default values including the IP address (set to receive an IP address using DHCP). To obtain the access point/bridge's new IP address, you can use the show interface bvi1 CLI command.
